gauge pod mount steering column
Old 02-08-2008, 04:32 AM
KRB
KRB's Avatar
I think I can count the times on one hand that mine has been over 80!
When I was trying to locate my tach on the column, before I made it permanant, I kept moving the pod around to see what was the best for seein and not covering up vital guages... thats the only spot that never hid anything I needed to know!
Old 02-08-2008, 08:53 PM
rockfoot's Avatar
I bought the column mount and the Isspro meter will not fit entirely into the hole... it (the gauge) is about 3/4" to long..... Maybe I am doing something wrong... the light in the gauge and the prongs for the dash style mount interfere with the flush fit as seen in KRB's photo...
Old 02-08-2008, 10:01 PM
ofcmarc's Avatar
I had to trim off the studs for the dash mount on my autometer as well and it was still a tight fit. got it held in the cup with a hose clamp.
Old 02-08-2008, 10:25 PM
well the 94-01 column pod is what is used on first gens too.get it on genos garage.However it is not what it appears to be. It is not replacing the stock one it has little stickies with it that are used to attach it to the column.We put and autometer egt in there (have to cut studs on back to fit) so when your going real fast and worrying about egt the speedo and egt are both right there.
Old 02-08-2008, 10:55 PM
ofcmarc's Avatar
I didn't use the sticky tapes. I got some short screws and screwed the cover to the original coluum shroud. Look close in the pic I posted earlier and you will see one of the screws.
Old 02-09-2008, 04:05 AM
KRB
KRB's Avatar
That's actually ofcmarc's photo but if you showed it to me I'd say its mine. Same interior color etc.
My Issopro fit the pod with minor modafications. I bought a spare column cover from the junk yard in case I wanted to remove the pod and return it back to stock. Drilled a hole in it for the wires to go through into the column plus the 3/16 holes for the plastic "rivits" that hold the pod onto the column cover (ofcmarc used screws in the photo). Had to cut off the mounting stud protruding from the back of the Issopro, slighly bend a spade connector and then a wrap of electrical tape to make the guage fit tight. That was it. Others said that the guage was too long and you'd have to cut the back out of the pod but they must have a different Issopro.
Old 02-09-2008, 05:20 AM
ofcmarc's Avatar
I think the Isspros with the lights are th ones that are too long
Old 02-09-2008, 05:26 AM
KRB
KRB's Avatar
Mine has lights too. It's the model that plugs in directly to the stock wiring. I'll have to lookup the part number.
Old 02-09-2008, 06:52 AM
GO OVRIT's Avatar
https://www.dieseltruckresource.com/...d.php?t=173561 Great writeup here.
Old 02-10-2008, 03:33 AM
KRB
KRB's Avatar
Yep, that says/shows it all. Was that a sticky?
Old 02-10-2008, 03:36 AM
ofcmarc's Avatar
It's the first thread at the top of the 1st gen forum. It's stuck there with a tack to keep it at the top. Full of excelant info.
Old 02-11-2008, 01:49 PM
A_port93's Avatar
thanks alot guys...im using mine as a fuel pressure gauge mount
53 willys
18
01-06-2007 06:44 PM
chw
12-25-2006 04:30 PM
cumminsboy
08-30-2004 12:00 PM
VueDoo
20
05-09-2004 09:07 PM
scottrod
12-13-2002 03:06 PM
Quick Reply: gauge pod mount steering column
