Gasket kit for the getrag?
I'm in the middle of pulling my tranny to install a new clutch and rear main seal and I'm 99.9% sure this is the first time the tranny has been removed. With that said, its covered in oily grunge from slow leaks, 16 years and 350,000kms (the gasket inbetween the transfer case and tranny is toast too). So while its out I want to replace all the seals and gaskets on it. Is there an actual gasket kit for the G360 or can I get away with some RTV ultra-black?
Ok, I figured that stuff would work. Also can a guy get the tranny mount bushings at NAPA or the like? Or is a a Dodge only part? Mine are rotten and falling apart and making the tranny have a bit of side to side play.
If You are pulling it might as well replace the seals, the gaskets I rather use a gasket maker like permatex but for the seals You'll need to replace them to stop a leak. I got My parts from this guys that are excellent in customer service 1800 658 2537.
ted_pulliam
07-16-2009 11:33 AM
jmccart
14
07-31-2008 11:46 PM
wildchild97
09-25-2007 02:44 PM
