Full throttle vs part throttle
Old 08-07-2013, 05:34 PM
Onemoparnut's Avatar
I have noticed that when I floor the throttle the truck does not seem as powerful as it does at say 3/4 throttle. It only makes 30 psi of boost at 3/4 throttle and 40 psi or so at wot so I must be fueling more but it does not seem to make more power. I read somewhere on another site that backing the high idle screw out can make the pump defuel at wot does anyone know if there is any truth to that? Maybe it is all in my head lol...
Old 08-07-2013, 06:44 PM
1st Generation Admin
BC847's Avatar
Did you move the throttle linkage to the other hole in the throttle bell-crank?
If so, move it back.
Old 08-07-2013, 06:54 PM
The throttle linkage is in the inner hole you are saying to move it back to the stock location? That would give me less throttle travel correct?
Old 08-07-2013, 07:15 PM
BC847's Avatar
Yes, and yes.
Old 08-07-2013, 07:34 PM
Received 2,469 Likes on 1,630 Posts
Too much throttle travel is making him de-fuel at WOT?
I have been looking into this high idle screw, throttle / linkage adjustment as well, as a way to get extra RPMs.
Old 08-07-2013, 08:10 PM
BC847's Avatar
With HIS particular throttle indexing and main fuel-screw setting . . .. yes.
Old 08-07-2013, 08:18 PM
Should I also put the high idle screw back in?
Old 08-07-2013, 08:33 PM
BC847's Avatar
I would. And set it so it just kisses the throttle-stop at WOT (as worked by the pedal).
Revisit your throttle indexing and main fuel-screw settings to ensure you're getting the most out of it. (Throttle indexing first, then main fuel-screw (adjusting based on run-away)).
(I ran into this same issue).
Old 08-07-2013, 08:38 PM
My throttle indexing has never changed what do you mean revisit the indexing?
Old 08-07-2013, 09:23 PM
BC847's Avatar
texttomakethepost
Old 08-07-2013, 09:31 PM
I thought that the indexing always stays the same? How do I index it to make sure I am getting the most out of it? I thought when they were off a notch they are hard to keep running. Sorry if I seem dumb here but I am kinda lost thanks for the help though.
Old 08-07-2013, 10:00 PM
mhuppertz's Avatar
There isn't a whole lot of difference in my truck between 2/3 and full throttle. I just figured the POD's were maxed out.
Old 08-08-2013, 12:29 AM
BC847's Avatar
IIRC, the 3200rpm governor-spring is a little longer than the stock/OEM governor-spring. With that, you either trim the new spring to match the former, so you can run the original indexing, or, you leave the new spring longer than the former, and take up the slack with reindexing the throttle bell-crank.
Either way, one can move the throttle indexing one tick this way, or that, and reset the main fuel-screw like you would otherwise (looking for just before runaway).
- To one extreme, you may be able to run the fuel-screw all the way in, with NO runaway.
- And the other extreme, run the fuel-screw in a lot less than before, and get runaway.
The latter of the two will get you more usable throttle range with maximum fueling.
Old 08-08-2013, 07:45 AM
Rick 12v CTD's Avatar
David. Iirc you switched to the 3800 spring. Did you clip that to match the length of the stock spring like you did with the 3200 when you were running that?
Sent from my Galaxy SIII via tapatalk 2
Old 08-08-2013, 11:30 AM
When I put my 3200 spring in I did not clip it or change the throttle indexing. should I remove the spring an clip it? The throttle indexing is in the exact same spot it was when it was stock.
Quick Reply: Full throttle vs part throttle
