Fuel weeping around filter.
So, my truck will leave a small spot of fuel on the ground. The filter is damp with fuel, but its tight and relatively new. Could it have something to do with the fuel heater? Are they prone to any problems?
Mike there is a o-ring type seal, looks identical to the large o-ring on the fuel filter, that goes between the heater and the block. this could be leaking I guess.. is the heater wet too?
taking the heater off can be a real PITA..
remove the filter and lay under the truck looking up at the threaded shaft the filter goes onto...
You'll see that it has a slot for a large screwdriver across it, or some years take a large Allen Wrench .. but that is how you remove and replace it.
when you remove it, pay attention to what side is "up"...and dont bugger up the threads...
I had the best luck with mine using a very very stiff putty knife as a screwdriver, since I did not have a actual driver wide enough to span the tube..
Also, check the bleeder banjo bolt above the filter first, they can seep fuel out if loose( but DONT over-tighten it-its brass and will strip out)
Just found that someone posted a pic of the filter tube in the classifieds.. you can see the slot for the screwdriver on the one on the right:
Order a short tube and do away with the fuel heater. Thats wat i did no leaks now and is easy to change filter.THE Short version has a allen head in the end of it so its easy to install.
Where did you find this piece ??
Can you give us a part number ?? maybe some pictures showing what is different ??
Thanks.
1st Generation Admin
LOL!! It's easy to get those things off!
Lay up under the truck wit a 2 foot or so crow-bar. Stick the flat end up in the slot of the threaded tube and unscrew it so as to replace the square-cut rubber gasket. Installation is the reverse.
I got over 200,000 miles from the OEM one in my heap. Just get another one from Cummins and continue running the heater.
My $.02
My $.02
Fuel Leak Around Filter
I got a short tube from Cummins a couple of years ago and did away with the fuel heater. The part number was: 3925954 (Adapter,Filter Head) - around $15.00. The price and part number may be different now. I use Power Service in the white bottle in the winter.
I know there are people with a different opinion about the fuel heater but I got tired of the stinking gasket leaking so I did away with it. I have run this truck in the winter at 0F and no problems yet. If you can't pump it out of the tank you can't run, just my opinion.
Jim
Jim
My $.02
My $.02
Joseph
The one on my truck once screwed loose when loosening the filter.
I am going to lay in a stock of those heater-eliminating stubs and get rid of the possibility of one coming apart beside the road some night.
Salvy
Yours is most likely off to one side shorting the WIF sensor. (It's a common thing).
Hope this helps.
JKE
10-11-2003 12:52 PM
