Fuel system rebuild
Old 05-05-2011 | 08:56 PM
mhuppertz's Avatar
Fuel system rebuild
Well, I got the tank and the fuel sending unit out, no dirt in the screen, but the bottom of the screen is torn and the plastic is broken.
If I am running a nice big replaceable filter right outside the tank do I even need to worry about the screen, or should I try to fix it?
I am a little worried about running without one....
Also, because the screen is not clogged, I must have a suction leak or a problem upstream like an LP issue.... I'm replacing the puckup tube (thanks DTS sticky) and all of the plastic line from the tank to the lp with metal.
Old 05-06-2011 | 03:23 AM
Bogie's Avatar
if your running proper filtration I would not worry about the in tank screen.
RiverRat2
10-15-2019 11:59 AM
wiskeyVI
13
03-20-2012 11:23 AM
mhuppertz
05-08-2011 05:43 PM
csa
04-02-2011 10:14 AM
