Fuel return line; I can't find it?
I just put new fuel lines on my Ramcharger from the tank forward. I know the pressure line goes to the lift pump, but, where on the engine does the return line go?
The motor is an '89 6BT non intercooled...
It shouldn't be any trouble to see.
Look just behind the lift-pump for a small steel line.
If you still don't see it, start at the injection-pump and follow it back.
The returns from the injectors TEE into the return from the pump on the left-upper side of the engine.
Hope this helps.
Hope this helps.
Rick 12v CTD
09-23-2011 05:21 PM
ctd4stan
05-18-2009 02:56 PM
Tiara3100
01-14-2008 10:06 AM
