Fuel pump spacer.
Old 09-12-2008 | 11:53 PM
proeliator's Avatar
Fuel pump spacer.
Hey guys im following the stickey and cant find the spacer anywhere online with that # anyone know where I can find it?
Old 09-13-2008 | 09:08 AM
We got ours at our local dodge dealer.
Old 09-13-2008 | 10:20 AM
BearKiller's Avatar
If you are meaning the spacer that goes between the engine and piston-lift-pump, that is a Cummins part and the numbers have been changed a couple of times.
The spacer is no more than a piece of 3/16" steel that has a slot for the pump-rod and two mounting holes; if you are careful, it is an easy accomplishment to make one by using the mounting side of the pump for a template.
Before you start, come up with either a couple of studs, or all-thread of the appropriate size, to install in the engine; rather than fighting with so many layers and trying to line up bolt-holes, it is much simpler to simply stack everything up on the studs, then apply the nuts.
Old 09-13-2008 | 01:26 PM
proeliator's Avatar
Ill call the dealer then, anyone know what stock use they had for the spacer?
was it on the 94-98's?
Old 09-13-2008 | 05:23 PM
89f150's Avatar
I thought i read somewere a small block chevy one would fit? or maybe it was for something else?
JBradley500
06-20-2010 05:31 PM
cedardiesel
03-03-2009 08:59 PM
hardheaded
02-17-2009 08:43 AM
BearKiller
03-14-2007 08:12 PM
goodtyms
04-25-2006 07:52 PM
