fuel pressure gauge? and best place to get?
Location: North Haven,CT "Living in occupied teritory" & Barton,VT
I sorry to hijack the thread, but if one was to switch to a 2nd gen mechanical pump. What "pressure"... fuel gauge should you get?
1 Post
I still don't like the idea... Someone borrowing my truck and not knowing what to do when diesel fuel starts to drip onto their feet...
That being said, if i had a place to put one i would. I think i'm jealous of his cool gauge cluster :-)
My old Mercedes had a mechanical oil pressure gauge from the factory. Didn't leak after 25 years even after I took it apart to take the cluster out a few times.
Just make sure you know how to tighten a compession fitting so it doesn't leak End of story.
Besides, diesel isn't that flammable at atmospheic pressure and normal temperatures. Spill some diesel on the ground and try to light it with a match or lighter. Not easy. We light off boiles on some ships with a long rod with an attatched rag soaked in diesel with a small blow torch. After we touch off the burner, we put it out by just sticking it down the holding tube full of diesel.
ha i don't let anyone borrow my truck...most people don't even know what egts are and thats the dangerous part! once in a while my dad will take it if he needs to tow somethin, but he's a diesel mechanic and he knows most of everything i have done to this thing and i trust him... but other than that, no one else drives the old girl unless I'm with them. Ha i guess i'm kinda selfish with my 1st gen, but its my baby and i think a lot of guys on here can relate.
1 Post
Just imagine what your friends will think when they cam make your little gauge go to 16 and... what would it be if this thing went higher...
Trying to comply with the rules here, but this is from Genosgarage.
" ISSPRO R5604R 2" EVA Mechanical Fuel Pressure gauge shows 0-30 psi. The gauge includes an isolator and 8 ft. tubing kit so you do not have to source these separately.
Black Face / White Lettering / White Illumination / Red Pointer
ISSPRO 2" EVA Mechanical Fuel Pressure Gauge (0-30 PSI) "
Fuel would be completely isolated 8 ft from the gauge, correct?
Thanks!
Thanks!
Would a 30 psi gauge be high enough if you swaped a 2nd gen motor into a 1stgen? I just did that and I have an isspro 30psi gauge. Will i nee to get a bigger one?
Thanks!
Thanks!
You'd want a 60 psi gauge with p-pump
Would a rotary lift pump cause the same gauge pulsations?
Has anyone adapted a rotary fuel pump of from a larger engine like a Detroit or Cummins?
It would certainly flow a lot more fuel and could be adapted to drive from the crank pulley.
Jim
So what is causing all of the pulsations? Is it the recip action of the mechanical lift pump or is it the chatter of the rotary pump in the VE?
Jim
Jim
1st Generation Admin
If you're gonna race in any sanctioned event, you'll find fuel lines in the cab won't pass. It's a fire/safety thing.
I run the ISSPRO Performax gauges (all electronic).
