fuel is leaking everywjere! Fuel Heater top quad ring gasket toasted
Ive got the new gasket but cant get to it? How can you get the filter stud off to access it?
3834185-S is the part# its only available at a cummins parts supplier, the incredible hulk must have put mine on I have spent all night trying to get it off and it hasnt bugged and its just stripping the slot
I believe that Bearkiller found that a spade type drill bit worked well. You can also get a wrench on the shank for a bit of leverage.
only if you lay down under the truck and are looking up at it
Another trick to try before buggering it up to badly is getting two nuts that will thread onto it.. use one as a lock nut against the other and turn it using the second one.. I did this a long long time ago on my first 91 to tighten the stud, mine kept spinning off with the filter!, but I dont recall at all what the size/pitch were...
knowing cummins its metric but it is filter side i took mine off with a set of needle nose vice grips there the stud goes into the housing while i was trying to spin the housing
Thread Size: 1-16 ~ thats what the filter that threads on there is, so that must be what the nut size was too!
I do recall I got the nuts through Fastenall..
i tried getting my seal from the dodge dealer before i took my fuel heater off and turns out they gave me some random other seal which there was no way it was gonna work so i just took the fuel heater off and took the old seal and put oil on it and put it all back together and it stopped my leak
I got mine at the local Dodge dealer parts department. $2.50 out the door.
I used a 3" long piece of 1" flat steel, ground the end down like a screwdriver and bent it about 9" from the other end as a handle to get the bung loose. Worked like a champ on a 4x4, not sure on a 2wd, though.
