fuel leak/air leak
fuel leak/air leak
I suspect I've got a fuel/air leak. I've been having an intermittent problem where it won't start. It's been getting worse. Sometimes it would start fine. Then I would go to the store and return 10-20 minutes later, and it wouldn't start. Cracking a couple injectors used to work, but now it's gotten worse. I can even crack all 6 open and crank, and after 20 seconds fuel will come out from each injector, but it still doesn't want to start. I've got a new 950 CCA battery, and the engine cranks fast but it's not getting fuel.
I opened the bleeder screw just after the fuel heater and pumped the lift pump lever perhaps 150 times, and I get nothing. I don't see fuel spraying or dripping anywhere. Although there is some fuel and/or oil oozing down from the LP. The LP was changed Jan 2013 and was purchased from Geno's Garage.
So I assume I should replace the LP gasket? Then what? What are the most likely and/or troublesome causes of air leaks?
maybe368 ~ I went out there and checked the FSS. That tiny nut on top was a bit loose. I tightened it up, then for good measure I metered the terminal connector on the blue wire, both key on and key off. The voltage was good, so I plugged it back into the FSS, turned the key, and she fired right up in about 1/10th of a second. Man, it can be so irritating when somebody else is right...
At least I don't have an air leak (knock on wood).
Glad ya got her fixed!
This is just an addendum but when guys are doing diesel swaps and everything's pretty much custom, I always suggest that they add about a foot 12" of clear vinyl tubing just before the fuel filter. It's a positive and instant indicator of any air bubbles or water or grunge in fuel line before fuel filter. Can really help in troubleshooting fueling issues.
maddddog
08-16-2019 07:20 AM
superdiesel9
10-25-2009 07:56 PM
