fuel heater
fuel heater
my fuel heater is leaking on the block side and since it is not hooked up and no provisions to hook it up I would like to do away with it altogether this is my first diesel and i stumbled across this site searching around one day and have not looked back since, any suggestions would be great
There is a different "filter adapter" that will thread into the head and let you put the filter on without the heater. I do not have the cummins part number for it, however. If you found a helpful cummins shop, they should be able to supply you with one.
Here ya go:
Fuel filter stud for use without fuel heater Cummins 3925954. Pricey, just checked this weekend, something like $17. If that's too rich for your blood, you can replace the o-ring/seal that is between the fuel heater and block for less than a couple bucks. Fuel heater square o-ring Mopar 4429695 or Cummins 3913695.
All Dodge diesel trucks have a fuel heater somewhere. On the '89-'93 trucks it's between the filter and the head. Later models have them in different locations.
http://www.reliablegoods.com/cgi-bin/sqlstore/index.cgi
This one installs with an allen wrench instead of having the straight screwdriver slot.
I bought a "tested" one online at $8.29 from:
I just got the adaptor from cummins and only took a few minutes to put in worked great just one question on the old adaptor for the heater there is a smaller o-ring on the filter threads was that o-ring needed to be changed over to the new adaptor THANKS
Yes. The o-ring is there to keep trash from migrating into the filter and to prevent fuel from escaping past the threads. You should get a new o-ring each time you purchase a new fuel filter... unless you bought FS1221. It doesn't come with one.
so I don't need the little oring with the fs1221 filter
I guess if it's not leaking, then you'll be ok. I just saved the old o-ring from the FS1232 old filter and reused it when switching to the FS1221. That o-ring, from what I discovered, is not available from Cummins separate.
rjm022
12-11-2019 09:17 PM
modiesel
03-07-2008 10:44 AM
