Fuel filter stud
Old 04-03-2012 | 09:17 PM
DodgeFreak's Avatar
Fuel filter stud
My fuel heater was leaking and i was going to buy the oring to reseal it but decided to just eleminate it, and from the search function i got the case part number but not sure what its supposed to look like it. heres the picture of it could you just verify that i did buy the correct part Thanks
Old 04-03-2012 | 10:02 PM
CRmopar's Avatar
That's it.
Old 04-04-2012 | 06:19 PM
Bencie's Avatar
The o-ring above the fuel heater is also available from cummins, thats probably where its leaking from. That nipple should have a slot in the end of it, if you have an ignition key without the plastic on it, that and a cresent wrench works good to remove and install it.
Old 04-04-2012 | 06:32 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
A flat pry bar works well too... mine leaked but it was just the stud backed out a little bit.
Old 04-04-2012 | 08:50 PM
DodgeFreak's Avatar
I know thats where its leaking from i priced the o ring out and it was 5 bucks plus 8 bucks freight, at two different placed, i was able to get the stud from case for 10 bucks and never have to worry about it again. It should come out fairly easy since it came out with the filter and i just snugged it up with a short screw driver lol.
Old 04-05-2012 | 04:48 PM
Kansascrewcab76's Avatar
FYI...
A wix 51036 oil filter o-ring is the exact same diameter (little thicker, but no conflict) and only costs $5-6. You could get it for less if you cross the number to a cheap orange fram from walmart.
Just my
qmikep
12-29-2013 05:00 PM
Diesel Jeff
01-09-2012 10:40 AM
archer39
02-23-2010 09:44 PM
BearKiller
02-17-2008 06:46 AM
74dart
07-07-2007 07:58 PM
Quick Reply: Fuel filter stud
