Fuel filter changing and oil change info.
#32
I guess I'll get my $.02 in here,I forgot what the reason was but I left
my oil drain overnight & when I went to take the filter off the oil was down a couple of inches & I've been doing it that way ever since.
It prevents any oil from falling out when you tilt the filter to get it out.
#33
Received 1,648 Likes
BK,
Question for you.
If you upgrade your FF to the fleetguard unit, what do you do with the wiring harness that warns of water in fuel ? Just let it dangle ?
I was looking up where to buy these filters, when I came across this thread:
http://www.cumminsforum.com/forum/94...questions.html
Did they change the thread mounting in a certain year ? I don't want to buy a case of these and then find out my threads are different on my 93, such as this guy was asking.
Secondly,
I spent 6 years wrenching for a local Napa store / repair shop and saw them on vehicles back in the early 80's. Handy feature, and made for little or no mess....
But
If you put one of those oil drain valves on your drain pan, do you not restrict flow during an oil change ? Meaning that if there is any "gunk" that broke loose in the engine, and found its way to the drain hole, wouldn't it get stuck at the back of that valve, hence preventing it's release out of the pan ? Possibly allowing it to recirculate ?
or if the KDP fell out (on engines not repaired yet) and you didn't know it was there because the valve was blocking it's exit from the pan, then it could possibly block flow or be recirculated back into the engine.
do you think these issues could be troublesome.?
BTW....
Enjoy your creative writing skills
T.
Question for you.
Secondly,
But
BTW....
T.
#34
As far as I know a B series filter is a B series filter.
That valve is a ball valve. If you open it and nithing comes out, stick a piece of stiff wire up in there to break it loose.
I don't know if the KDP could come out of the pan, but once it is in the pan, it's in the pan, unless you go running it upside down or something.
#35
BK,
Questions for you.
That, or fold it out of the way and zip-tie it, or just follow it back and clip it off.
Once you start using the solid-bottom filters, that plug will never be used again anyway.
So far I have ever known, the same fuel-filters and oil-filters fit from 1989 to 1998.
According to the bit that you just found, there must be some odd ones out there.
Do a little research on the filter-number that you know will indeed work and see if it's mounting threads agree with those of the FS1221.
I cannot speak for stuff that is hundreds of miles away from me, but we have a lot of Cummins engines around here and the FS1221 fits and works on all of them.
Secondly,
But
BTW....
T.
Questions for you.
Secondly,
But
BTW....
T.
Although I have not yet had a Fumoto valve screwed into an oil-pan that was not mounted on an engine, to see just how much, if any, of the valves threads poke up above the pan's bottom, I have indeed seen the insides of many an oil-pan.
In every oil-pan I have yet seen, there is a THICK re-inforcing washer, and in some cases a thick plate of steel, welded inside the pan's bottom with the plug being threaded into this thick metal, NOT the paper-thin sheet-metal of the pan itself.
If fact, it is a very common problem on many of the disposable cars that have outlived their life-expectancy for the weld of the reinforcing washer to break free and allow it to spin loose when trying to remove the drain-plug.
It is such a common issue that the parts stores carry repair kits that include a new weld-in reinforcement and new drain-plug.
In each case, there is a depth of between 1/4" and 3/8", give or take, around the periphery of this re-inforcing metal, that NEVER gets drained and always stays inside the pan.
You bring up a good point and one I have already considered myself on a number of occasions.
If I can ever remember to do so, I will take a Fumoto valve over to my friends diesel shop and screw it into a pan that is not mounted, just to see how much, if any, protrusion there is.
I guess another way to know would be to measure from the top of the threads of the Fumoto to it's mounting base, then, with oil drained, poke a 90* pick-tool through the drain-hole and hook it on the top surface of the pans reinforcement, take this measurement and compare.
Carry on.
Black SunShine 04
46
01-04-2010 03:18 PM
jmccart
13
05-27-2009 09:45 PM
vegashd
07-15-2007 12:24 PM
doitl8r
06-04-2004 11:14 AM
