Front springs
Front springs
92 4wd got new springs with another ply under main one the full length just like my old plow truck was .Its out there with no motor but the springs are arched don’t remember with motor if they were flat or not.But these are flat on this truck with jungle hangers on the back and the eyes are against the frame.What u think
If with no weight over the front end, the shackles are angled to the point where the eyes are touching the frame on the rear of the front spring, you need different springs, and /or at minimum longer shackles.
It will ride awful like that AND destroy the frame as every bump you go over will try to rip the front frame apart as the spring has no where to travel.
I would return the springs and get the proper ones, as when there is weight on those springs it will only get worse.
If with no weight over the front end, the shackles are angled to the point where the eyes are touching the frame on the rear of the front spring, you need different springs, and /or longer shackles.
The Jungle shackle is installed backwards I believe.
I don't think flipping it will keep the leaf spring off the frame, as the spring is too long.
You need a longer shackle at minimum to fix your issue. A better spring pack would be ideal though.
My white '85 crew cab with Skyjacker 6 inch springs sagged a bit over the years enough that the spring eye to frame clearance looked like your picture. It would contact the frame when I went over a decent bump in the road on the drivers side.
I made up a set of 1/2 inch longer shackles [for both sides] and it has been good for the last 7 or so years.
Received 1,648 Likes
Your main leaf is too long.
I experienced the same issue. I pulled the springs back out, dropped them back off at the spring shop, and they corrected it.
If you don't do anything, you will do what Ollie said, and damage the frame.
Yea this sucks I’ll call them today and c what they say Or this winter just go with a skyjacker 4” lift and to think I Thought I was done for a while
Tell the spring shop that you want new u bolts. They're not supposed to be reused. Make sure you torque them to spec, then recheck in 50 miles, 100 miles, etc.
I had lots of problems with front springs on my 92. I got to the point that I could get them out in about 45 minutes with air tools.
Called the spring shop yesterday told him what’s up he says something doesn’t sound right he wants to look at them .So I guess I’m going to have to take a 120 mile trip he sounds pretty sensere we’ll c .I had the u bolts made at another place so I’m going to wait and c what he says and go from there.
Looks good. If the eye still hits the frame, get a longer shackle. It helps your caster anyway. I made mine with holes at 5, 6", and 7" length.
I combined two old leaf packs to make one super-stout setup. Price was right.
