front brake rotors on 92
does anyone know the casting number for the rotors on a 92 diesel with the dana 60 front axel the parts store says they have 2 different #s and need to know which ones i have I thought all diesels had the same HD rotors thanks for any help also maby bearing hub numbers or where to find them they say their not available
no there really are two different rotors and it is a PITA to get the number without having the rotor off. It is possible though, you'll need a flashlight and some luck. I just went and looked at my old rotors, and the number on them is 100363 and it is on the inside of the rotor next to where the hub presses on.
I thought I had written the bearing numbers down somewhere, but now I can't find them.
Both will fit because they gave me the smaller ones and mine had the larger ones. I would have taken them back but it was Sunday and I had to have my truck back on the road 6am on Monday. I would just get the larger ones. they worked better when I Finlay changed them out.
thanks for the help ill try the numbers u guys gave me and see if they interchange in AZ computer hope to get the parts before i tear it down Gotta Love this site!!!!!!!
The guys @ O'Reillys figured mine out through the weight rating of the front axle. I don't remember the number, but I checked the tag/sticker on the drivers side door jamb and they got it right!
Hope this helps, someone!
04ctd
08-03-2007 04:19 AM
Mr. Jimmy
03-28-2005 08:29 PM
