frame
Old 11-30-2014, 02:22 PM
cabtruck's Avatar
frame
I have a 1993 club cab w250 frame going to going to build a truck from the ground up if I run a string from the back to the front and measure to the frame front the front is over 1"so it's 1/2" out how close are they from the factory
Old 11-30-2014, 04:34 PM
j_martin's Avatar
If all the wheels run in the same lane, it's good.
Old 11-30-2014, 05:18 PM
cabtruck's Avatar
I don't want to build a truck from the ground up and then have problems already have a rebuilt 12 valve p pump and g56 transmission rebuilt 205 transfer case don't want to cut corners
Old 11-30-2014, 06:55 PM
BHD
BHD's Avatar
I'm not really sure what your are trying to say. Is it out of square or is it twisted longitudinal? Dodge truck frames are as stiff as a wet noodle. I don't think it would be hard fix one.
Old 11-30-2014, 07:36 PM
cabtruck's Avatar
Front is over to the left about 1/2" frame is not diamond it's level square and straight from the transmission cross member back just over in the front I think it will be ok just wanted another option
Old 11-30-2014, 09:07 PM
sooty's Avatar
where do you live?
Old 12-01-2014, 05:01 AM
cabtruck's Avatar
South Carolina
Old 12-01-2014, 07:23 AM
j_martin's Avatar
Sounds like it got smacked on a front corner and racked a bit. Should be an easy "adjustment" for a collision repair center with a frame rack.
Old 12-01-2014, 07:34 AM
Angry Johnny's Avatar
1/2" isn't anything to worry about. It could have easily been that way since new.
Old 12-01-2014, 09:06 AM
sooty's Avatar
shoot, im scrapping 2 frames with lots of parts, but angry is right, your measurements between spring and body mount perches will be points of interest, the body perches allow lots of movement for alignment, so really the focus is spring perches corner to corner, to get the axles tracking straight, real frame damage will visibly show with paint peeling around slight bends.
Old 12-01-2014, 12:39 PM
mknittle's Avatar
Measure in a X pattern. Left front to right rear then right front to left rear also to check for square. Measuring frames can be a bit tricky.
Note: 2WD and 4WD frame dimensions are the same.
Old 12-01-2014, 12:55 PM
cabtruck's Avatar
Thanks for the info I think I'm going to use it and if there is a problem put it on the frame machine after I'm done
Old 12-01-2014, 03:04 PM
mknittle's Avatar
Now is the time to fix anything bent while it is easy to get to.
Old 12-03-2014, 12:51 AM
NE frmhnd's Avatar
And once you get it straight, box the whole thing and add a couple crossmembers. While you can get at it easy.
Old 12-03-2014, 09:42 AM
mknittle's Avatar
Even more so if it is the six inch early frame.
Quick Reply: frame
