Flexplate questions
Flexplate questions
Howdy everyone. I'm going to be jerking the transmission to replace the rear main sometime in the near future, as some of my earlier threads indicated. Since I am going to get an upgraded torque converter and the 1st gen flexplate is weak anyway, I am going to upgrade. First, I found a flexplate from a 99 my Dodge with the 24 valve. Will this work? Also, what are the torque specs on the flexplate bolts, and what kind of locktite should I use? I will appreciate any advise. Thanks!
What is the part number for the Cummins flexplate? And, again, will a 99 model 24 valve flexplate work? Also, what are the torque specs for the bolts?
from the FAQ section:
I just orded that flex plate from Cummins myself, by the time I paid taxes and shipping it was just under $130 to my door.
I'm not sure on the torque specs... actually, i'd like to know those myself...
Updated Flex Plate
This is the part number for a 95 model. This is a direct bolt on for the 1st gens and should be used in place of the old part number for added durability especially on modified trucks.
Chrysler Part # 5015709 Price $295.00
Cummins Part #3946161 Price $ 94.22
Just curious here, whats so bad about a used one? Is there a chance that it is out of balance, or cracked, or something like that?
BTW, thanks for the replys. I am going to check out a new flexplate as soon as I get to a Cummins dealership.
Just get the one through Cummins.
A used one for a new truck could spell bad news there could be stress fractures in it that you can't see. The lock up converters put alot more stress on the flex plate.
Spooler
33
10-15-2008 04:47 PM
cLAYH
08-10-2004 12:40 AM
