First start in a year
Old 12-09-2023, 07:58 AM
49 Ford's Avatar
Thanks, yes I think it’s going to look pretty good when done. Hopefully I don’t get any expensive surprises when I finish it. Don’t know the history of the Dodge. I had the Cummins running on a stand for an hour and seemed good. Transmission I know nothing about. 3 speed auto in it🤞
Old 12-09-2023, 08:05 AM
49 Ford's Avatar
I have a question for you KRB. My tappet cover looks like it’s 34 years old which it is. I was thinking I should replace it for I’m not sure how good it’s sealing. The motor is sitting on my work bench so it won’t get any easier. I’m guessing I would have to take the pump off to get at it. Any experience with that
Old 12-09-2023, 08:19 AM
Received 2,533 Likes on 1,675 Posts
Yes pulling the VE pump is the usual way to swap out that tappet cover gasket.
I like to rotate the engine over till the key away on the VE pump is facing up before pulling the pump. I feel it is less likely to drop into the timing case than it would be if it was facing down.
With the much bigger injection pump on the later P-pumped 12V I see no way to do it other than pull the pump.
The following 2 users liked this post by oliver foster:
nonrev (12-10-2023), nothingbutdarts (12-09-2023)
Old 12-10-2023, 04:10 AM
KRB
KRB's Avatar
I'll defer to Oliver's response. Been a while since I adjusted mine (after the new headgasket) but I did it in the truck with everything attached. I'd definitely replace it now, it will never be any easier. And if you don't - it's things like that that take the opportunity to prove Murphy's Law.
nothingbutdarts (12-11-2023)
Old 12-10-2023, 10:32 PM
49 Ford's Avatar
Removed the pump and pulled off the tappet cover which was soaked in oil so I’m thinking there was a problem there. Trying to decide if I should replace the shaft seal on the pump. It’s not leaking
Old Today, 08:41 AM
49 Ford's Avatar
Hi there thought I’d post an update on my truck with a question on my turbo. I want to upgrade the little turbo on the 89 Cummins to one that’s off a 91. This truck doesn’t have an inter cooler. I’m guessing there won’t be a problem it’s not much of an upgrade.
Old Today, 12:34 PM
You will have to re clock the turbo to blow over the valve covers. You will also need to re engineer the way the crossover pipe attaches to the turbo outlet.
Then finally you will need a different air filter tube to deal with the bigger inlet of the '91 turbo
Depending on the size of the exhaust housing on that 91 turbo it might not be an upgrade as it might spool up very slowly. Look for the #s 18 or 21 cast into the housing.
Personally I would find a HX35 from a 96-02 and use that. Now that would be an upgrade worth all the work to make it fit.
Old Today, 12:36 PM
The truck looks great. Is it just my eyes or are the two side mirrors at a different heights?
Are the post that adjustable?
nonrev
10-15-2018 08:15 PM
deking1970
06-22-2010 07:57 AM
92 Bob
02-08-2009 03:29 AM
city slicker
10-30-2008 06:11 PM
dandyalgleish
09-16-2007 05:52 PM
Quick Reply: First start in a year
