First start in a year
Old 03-19-2023, 11:37 AM
49 Ford's Avatar
I’m building a truck and have got to the point I wanted to start it up. I have changed the fuel pin and governor spring. So when we started it it went to high rpm’s. We quickly shut it off. The power screw hadn’t been screwed in which could create a run away. After many attempts with the same results we took pump apart to see if I had made an error installing the fuel pin and spring. Everything looked fine. My motor is a 91 and I have completely removed the ecm and wired it myself. So if anyone has an idea please let me know. Thanks
Old 03-19-2023, 03:38 PM
49 Ford's Avatar
Well we figured it out. On the splined shaft on the pump where the throttle hooks to we had to move it one spline notch.
The following 5 users liked this post by 49 Ford:
NJTman (03-22-2023), nonrev (03-20-2023), nothingbutdarts (03-19-2023), Rug_Trucker (03-20-2023), thrashingcows (03-20-2023)
Old 03-20-2023, 05:04 PM
Rug_Trucker's Avatar
When I did my spring I marked it with a Sharpie. Then sprayed with carb cleaner after removal. It removed my index mark.
Welcome to the forum!
Old 03-22-2023, 07:25 AM
Received 1,647 Likes on 1,120 Posts
I counted the little index lines, and didn't have that happen again.
nonrev (03-22-2023)
Old 03-28-2023, 03:11 AM
KRB
KRB's Avatar
Out of curiosity, what's the motor in?
Old 12-06-2023, 08:05 PM
49 Ford's Avatar
It’s in the 91 D250 but a 1949 Ford sits on it.
The following 3 users liked this post by 49 Ford:
brentm (12-06-2023), edwinsmith (12-07-2023), nonrev (12-07-2023)
Old 12-07-2023, 05:04 AM
KRB
KRB's Avatar
Hmmm, I'm not sure you'll get away with posting only one picture of that.
Do you happen to have a build thread somewhere?
Old 12-07-2023, 06:34 PM
49 Ford's Avatar
No I don’t have a build thread, not that techie, but it started as a 3 ton truck, I’ll include a few more pictures.
Where it sat for 52 years
Tight fit getting that Cummins and rad,intercooler in there
Old 12-07-2023, 06:39 PM
49 Ford's Avatar
Here is a wow moment when we finally started it after a year and a half
File Type: mov
Old 12-08-2023, 04:41 AM
KRB
KRB's Avatar
Wish I could make that sound my ring tone!
Thanks for sharing. Really cool.
On a scale of 1-10, how easy/hard was it to mate the Ford body to the Dodge chassis?
Old 12-08-2023, 01:34 PM
49 Ford's Avatar
It was not that easy but the results are worth it. I’m presently putting a Chev truck on an 89 W250 with another Cummins. Buggar for punishment
A lot harder with a 4*4 very little room. This has no inter cooler
33 inch tires and a body lift
Old 12-08-2023, 01:46 PM
Received 2,533 Likes on 1,675 Posts
I see you had to do a little fire wall work on that Chevy.
Nice looking trucks your putting together.
The lack of intercooler on an old rig with a narrow front grille and little space would be the way to go, I would think.
Old 12-08-2023, 06:08 PM
49 Ford's Avatar
On the Ford I moved the engine back 3.5 inches on the frame but the Chev is 4 by 4 so would need both drive shafts adjusted so instead was far enough ahead I got to put a new straight firewall in. Plus it was rusted and some of the floor.
New 14 gauge firewall
Old 12-08-2023, 06:11 PM
49 Ford's Avatar
My cab.
Old 12-09-2023, 01:50 AM
KRB
KRB's Avatar
Firewall looks almost original once painted.
Dang nice shop btw.
Quick Reply: First start in a year
