First Gen TPS help please
I am getting closer to installing my E40D automatic and now I need to come up with a TPS, Can someone tell me if I only need the TPS or is there some other brackets or anything else I would need? FYI My Engine was from a manual trans. Also where is the best place to get this stuff?
TIA
Rock
TIA
Rock
TIA
Rock
TIA
Rock
Im not worried one bit about the E40D handeling the Power, Ever hear of Maddog? He has around 1000hp with an E40D. If built right the E40D will handle the power. I have a 550+HP PowerStroke with an E40D and it works just fine. I also know it takes a Stand alone Computer to run the Transmission and I have that already. Its called a Baumminator made by Baummin engineering.
I Am A http://www.brianstruckshop.com/ Dealer and Brian can and does build the E40D and 4R100 to handle the power.
I have a 96 12 Valver that was an Auto but I am pretty sure the TPS and bracket are different. I may be able to make a bracket if I knew what it looked like.
PowerWagonCC80
05-05-2015 12:34 PM
