first gen compound turbo ??
Old 10-02-2006 | 03:00 AM
swampthang's Avatar
hi i have done some searching here and i am not finding much anyway i have a 1993 ctd p-pump conversion nv4500 conversion lucas pods and i am wanting to go with a compond turbo set up (twins) is there any one building these for the first gens ?? if so links please and i was also looking into building a set but i really dont know where to start i know how the compound turbos work and that is about it really dont know anything when it comes to mounting and oil etc... thanks in advace Jason
Old 10-02-2006 | 08:06 PM
PDR sells a kit.
Old 10-03-2006 | 04:31 AM
swampthang's Avatar
any that are not $4,000+ that is what the pdr kit is i have the tools and welding skils to build my own just alittle lost on how the turbos mount (second one ) and how to run the oil lines (split i guess)
Jason
Old 10-03-2006 | 06:55 AM
Begle1's Avatar
There's a second port availabe for oil lines which is unused on the stock trucks; you can take oil out of this one. (I think you need to tee it on the return.)
Typically you find an HT3B turbo off a Mack truck for around $400, and use that as a bottom turbo. Then a WH1C or HX-35W for the top turbo; just something with a wastegate.
Mounting I believe is usually done with a metal bracket bolted between the manifold and the head. I'm not too sure about that though...
Old 10-03-2006 | 04:16 PM
Swank has a link in his signature to his web page. He's got a lot of pics of the twins he built on there.
Tedonlin150
02-27-2010 11:40 PM
bombed24v
84
09-26-2008 11:34 AM
07nbcowboy06
08-21-2008 05:25 AM
Spooler
05-12-2008 10:06 AM
diesel des
06-02-2006 10:18 AM
