Finding a short in reverse lights
My fuse keeps blowing on my reverse lights. It doesnt always blow immediately, but usually after a few back ups. fuse is 20amps
Any tips on how to track this down easily?
Check your 7-way trailer connector if you have one, mud, slush and road salts will short circuits to ground or to each other, also check for pinched or abraded wires in the harness along the frame.
Jim
Jim
Sometimes the harness gets trapped between the spare tire and the frame. Shorts happen. Like Jim says they happen most often in the trailer connector. I just bought an assortment of solder lugs with varying wire sizes and #6 holes. Next time I have to go into mine I'm going to wire it so it doesn't get rearranged every time I hit a snow bank or something.
Immediately behind the taillight assy seems to be a common place for the harness to get pinched and short out
IIRC the lighting harness runs down the driver aside frame rail and across to the passenger side..tho I'm not 100% sure of that
tntshrekuk
06-25-2008 12:02 PM
Dodge@KY1997
12-21-2006 04:50 PM
