Finaly got my junk on a Dyno
Old 04-25-2010, 06:37 PM
Best Paint (Getrag category)
pulltilbroke's Avatar
Well, I finaly dynoed today on a dyno that has earned the name Dreamcrusher. I didn't get the numbers I was hoping for but I did find that I have a very flat hp and tq curve from 2200-3700. I'll have the graph up later.
It was a Mustang SE 1750 load style dyno
My numbers were
307.1 672.4 uncorrected
316.5 693 corrected
302.4 668.2 uncorrected
312.3 690.4 corrected
294.8 665.1 uncorrected
304.4 687 corrected
Old 04-25-2010, 06:43 PM
93flatbed's Avatar
And with all of those fancy mods I'd think you'd at least break the 550HP level!
Well at least you have nearly doubled the hp of the "factory hp" and now know where you stand.
I can only hope to break the 300 mark, if I ever do try the dyno.
Old 04-25-2010, 06:45 PM
big stinky's Avatar
5 speed and stock injectors?
Old 04-25-2010, 06:56 PM
Yes big stinky, 5spd and N/IC sticks and a 360,000 mile engine and pump. I was hoping for 350ish but oh well. at least I got a base line.
Old 04-25-2010, 07:23 PM
Even your torque seems low i think the dyno is messed up. not bad though.
i don't think the 93 would break 200 on the dyno but **** it moves
Old 04-25-2010, 07:31 PM
All the trucks seemed lower than they should be. but that the way a Mustang dyno is I guess.
I am running a fair amount of timing also, This was on my pulling setup, and as long as it goes down the track good thats all I care about.
Old 04-25-2010, 07:35 PM
92smokin blacky's Avatar
Not too bad of numbers. A good base number to work up from there. Our trucks sound pretty close, but your actually gettin yours to the ground with your manual.
Old 04-25-2010, 07:44 PM
The_Head's Avatar
You're getting your power to the ground too, but you'd be putting more to the ground if you had a manual transmission.
Old 04-25-2010, 07:56 PM
Yeah i know I am gettin it to the ground, but just not all of it...
Old 04-25-2010, 08:16 PM
pwrtripls1's Avatar
Not a bad dyno though for stock injectors, what turbo are you running?
My only dyno with the 92' was straight piped, pump turned up, and 12cm exhaust housing. Even then with a brand new LP I was seeing 0psi after being at WOT for a few seconds. I've sence done a ton of work and mods and as soon as I finnish up the IC install and get the SBDD clutch in I'm going to redyno it. I'm going to be really upset if I dont break 400whp this time.
Old 04-25-2010, 08:23 PM
H1c with HTT stg IV compressor
Here is the Dyno print out.
Old 04-25-2010, 08:29 PM
pwrtripls1's Avatar
Looking at that graph you either need more timing or you started starving for fuel in the higher rpm's. There is def some power still there. Judging by the 2100rpm tq peak I'd say more timing and you'll see some higher numbers.
Old 04-25-2010, 08:37 PM
I am also still running through stock lines and filter.
Old 04-25-2010, 08:42 PM
dieseldawg604's Avatar
i agree
the dyno i use is a mustang 1500 and ive heard a couple of guys say that they are way low compared to other dynos
like in the 50 hp range but thats on a 500+ 3rd gen
id sure like to find a generous dyno and see what the difference is?
Old 04-25-2010, 08:49 PM
you did alot better than i did with the stock fuel system i only made 275hp 640tq!!!
Quick Reply: Finaly got my junk on a Dyno
