Fan clutch best Source?Brand
Old 01-24-2009 | 07:58 PM
ScottNGa's Avatar
I searched for the best brand to get, but never could find the best.
Tried a Autozone special, turned out to a POS. It was worse than the used one from the factory. Rockauto carries the same part number under a different name, so I don't want to try one from them.
Any suggestions.
Old 01-24-2009 | 09:46 PM
PapeCAT's Avatar
I know you can always go to the dealer and get the updated fan and clutch. I am currently using a Haynes heavy duty from NAPA.
Old 01-24-2009 | 10:08 PM
ScottNGa's Avatar
Is the updated one from dodge the one that fits newer models? I read they have a lower lock up temp.
Old 01-24-2009 | 10:24 PM
PapeCAT's Avatar
Maybe someone else can chime in on that one.
I heard it locks at lower temps as well, but I haven't seen it. When I tried to order one, they weren't able to get one in for weeks so off to napa I went. It works great. I was always annoyed with my stock fan with all the noise it made all the time. But I found out that a new clutch allowed it to freewheel when cold or on the hiway when not needed and it lowered the DB in the cab substantially.
Old 01-24-2009 | 11:50 PM
BearKiller's Avatar
Like the steel-belted radial tire, I don't think they can build a genuine good fan-clutch that actually works when it should.
When the local NAPA Car Care Center over-hauled the A/C in the wife's truck, they installed THREE different brand-new NAPA fan-clutches and EVERY ONE of them were junk.
When they called me and asked if I could possibly find a clutch that would work better, as the A/C would not perform with a bad fan-clutch, I said "YEAH, I think I can take care of that."
I took the old "bad" clutch home, done my little "clutch pinning" trick, and problem solved.
Old 01-25-2009 | 09:35 AM
ScottNGa's Avatar
You had the same problem I had I belive. The new autozone clutch made it runner hotter than ever. Tried running the a/c and the head pressure was so high it blew the rupture disk out of the dryer, the brand new dryer.
Pinged it with a hammer but is now coming apart I belive.
Old 01-25-2009 | 02:19 PM
Alwaysworking's Avatar
alwaysonDTR
i got a fan clutch from carquest seams to work good and it was made in the USA.
Opus
03-14-2011 02:12 PM
jlipskoc
10-06-2009 06:29 AM
leonesm
09-15-2008 04:01 PM
GaCamper
07-13-2007 08:55 PM
big jimmy
07-07-2006 02:33 PM
