fan
Fred, would that only be a 2nd gen with a 12V? There's only available locally and the seller indicates for a 98 to 02.
I'm not sure if its an upgrade but I need a fan for my project.
Thanks,
Thanks,
Ron, IIRC, the 24V will work. I thought I read somewhere it was considered an upgrade. When I look at the stock on my 93, it sure seems the same.
To confirm, take some measurements. Again, the spacing from fan hub to motor should be the same, its the forward portion to the rad, that just needs to be verified. Diameter and splines on the hub should be identical, too.
MmmDieselFumes
09-27-2007 06:44 PM
MmmDieselFumes
09-27-2007 03:04 PM
