exhaust housing size?
I am just getting around to being able to work on my truck after the accident.So on sunday i took the turbo assembly off my 92,to put on my 93.When i got it off i check the numbers on the back side of the exhaust housing to see what they said,as i was told when i bought the truck that it had a 16cm2 housing.well the numbers stamped on it are 23m7 and then there are some other number stamped on it 1045910. Can anybody tell what these numbers mean?
Thank-you
Lee
Thank-you
Lee
Thank-you
Lee
Thank-you
Lee
Some one on this sight had a link to a sight that crosted the part mumbers and i though that it was in the...look here first... but i can't find it if it is there!
If you hold the housing like it's bolted to the ex manifold, it will be on the fire
wall side of the housing If it's a 16 or a 18(18.5) Holset it will be cast in to the housing!
Hope this helps
Thank-you
Lee
Thank-you
Lee
Turbine Housing 16cm
Product #: 1045910
1988-93 5.9L; 16cm Non Waste-Gated Turbine Housing
Greg
Thanks everyone for all the help,i appreciate it.
Found out yesterday that i have to go under the knife as my sternum is not healing properly and they are going to have to wire me together,oh yippee!!!
thanks again
thanks again
diesel_man98
06-23-2008 07:24 PM
HOHN
12-07-2003 02:07 PM
