engine won't shut off
I was getting ready to pull my truck today. I had advanved timing 1/8". Turned the fuel screw about 1/2 turn. I started truck, was driving it to the pulls. Stopped and tried a full throttle run. Now engine won't shut off. I tried pulling wire from solenoid. It stays running.
When the fss goes bad it wont hang in the rpms it just wont shut off. Are you sure you were using the manual shutdown lever? I have necer heard of that not shutting the truck off. Maybe some one who knows more than me will chime in.
Location: A 5th dimension, beyond that which is known to man.
1 Post
if im not mistaken (which i probably am) the shut down lever is on splines... if they are off one spline i could see enough fuel getting by to keep the engine running.
1 Post
some people dont like a pull cable shut down, but i love mine. i even have my GF's Neon running without the key in it (ok i didnt do it, its just a POS)
1 Post
well kind of... i took the plunger and spring out just so i knew the key would never work and the plunger wouldnt rip again and leave rubber in my pump. i like consistency. you dont NEED to do anything to use the shut down lever on the side of the pump.
pull the solenoid out and put the plunger in the grinder and grind the rubber down til you can see the metal, buff the edges so they are round and put it back in. I did this and mine is still shuttin down. Its in the sticky. It wasn't that bad to do as i thought it'd be.
