Engine shut off plunger?
My fuel plunger has bit the dust...I really don't want to go to a pull cable just yet. Does anyone have some pic's of how to get to the plunger, or a link to an already posted thread? I'm not to thrilled with just winging it!
Also with this thing having bit the dust...can this cause fuel to leak from the pump?
Thanks, Tony
Thanks, Tony
https://www.dieseltruckresource.com/...d.php?t=117593
all info in that thread, it was in the "sticky" at the top of the fourm
If you have a stock lift pump, the stock plunger will work. If you put a piston lift pump on the truck, it will eat plungers like candy. Trust me, I know.
Tony
1st Generation Admin
The plunger shown in the images of that thread lasted about two years before it started not being able to pull in (no fuel, wouldn't start). It turns out the barrel of the plunger was at some point in time dragging against its side in the solenoid housing (found definite skid marks).
Replacing it recently with a new, reshaped from the start plunger has all working as expected (maxed IP, DDP4 injectors, Walbro 392 regulated to 18psig at the IP, 3/8" ID fuel supply from fuel pick-up in tank to IP and back).
alwaysonDTR
