engine rebuild kits
Old 01-10-2009, 07:57 PM
comptz's Avatar
engine rebuild kits
I have a 1989 ctd 4x4, auto, and i am wondering where the best place to get an engine rebuild kit from.
Old 01-10-2009, 07:59 PM
Cummins is the best. If you need to rebuild one of these it's usually cheaper to swap in another one though.
Old 01-10-2009, 08:02 PM
comptz's Avatar
ok. Do you know what the kit would cost? my local machine shop said a grand for the kit and a grand for the labor to machine and put it back together. Im just trying to figure the total cost that would be involved.
Old 01-10-2009, 08:18 PM
peobryant's Avatar
Just curious, but why do you need to rebuild it?
Old 01-10-2009, 08:23 PM
comptz's Avatar
i believe it is getting low on compression and its starting to leak more oil than it did and plus im getting a bunch of blowby and i have some oil dripping out of the blowby tube and then the mileage
Old 01-10-2009, 08:40 PM
alwaysonDTR
Alwaysworking's Avatar
adjust the valves lately?
Old 01-10-2009, 08:45 PM
comptz's Avatar
No, Should i?
Old 01-10-2009, 08:46 PM
alwaysonDTR
yes always a good idea
Old 01-10-2009, 08:47 PM
1stGen545's Avatar
The cummins dealer told me they dont make a "kit" for the B you have to get it all seprate. everything and the machine work was just over 1k for all of it. that was new pistons, rings, wrist pins, bearings, oil pump and every gasket, oring, and all.
comptz's Avatar
How much should this help?
Old 01-10-2009, 08:53 PM
alwaysonDTR
they run a lot better with properly adjusted valves and its free if you do it yourself.
i'd try the valves before i bought all new parts.
maybe your fuel filter is getting plugged or your lift pump is dead, did it get colder outside all of a sudden making it harder to start?
things i would wounder berfor the worst case senario
Old 01-10-2009, 08:57 PM
comptz's Avatar
it will start but it just wont get up and go that well
Old 01-10-2009, 08:58 PM
Best Paint (Getrag category)
pulltilbroke's Avatar
These guys have treated me pretty good
http://www.endurancepower.com/v2/#/contactus/index.htm
Old 01-10-2009, 09:36 PM
Exekiel69's Avatar
Not too long ago there was a thread where the truck had lost power, turns out the lift pump was actually broken and was pumping hardly any fuel, may be something else to check.
Old 01-10-2009, 09:39 PM
If it starts easy, has good oil pressure, and isn't making funny noises I doubt it needs a rebuild.
Low power can be caused by a lot of things and most of them involve the fuel system.
If it's not leaving puddles under the crankcase vent your blowby is normal. They do that.
Quick Reply: engine rebuild kits
