Engine Degreaser
I use a good long screw driver to break up road grime-tar-cement that laughs at virtually any degreaser. I then use dish soap and various brushes. I finish with a good power wash at a car wash. I have found this to be real effective for me...Mark
just a couple things to think about....
if it cuts grease it can damage paint.
use plastic and mask off the fenders and front end.
some of the stuff that works good will also turn naked aluminum
gray and make it foam up, and will not shine any more.
if it's been baked on for many years it will take a preshure
washer or screw driver.
don,t learn the hard way, take advise from the ones that have.
Darwin
Darwin
Thanks for the info Guys, I just may go with the Oil Eater, I have done some reading on it and it has got my attention. I have seen the Purple Power also but have not used it. I want to cleasn the engine good and repaint it. I will mask off any areas that will be affected by it.
What ever you use just do not use Oven Cleaner, it is corrosive and will destroy anything aluminum.
I use Simple Green 100% and then a high pressure hose to remove it, I then dry it off using compressed air and finish up drying out all of the electrical connections.
Then warm the engine and go for a drive to get any of the moisture that might be left.
It also helps that I wash out the engine bay every time I wash the truck.
I also use a solvent gun to place it on the difficult areas using pressure.
Jim
Jim
Citrol works really good, but you may want to cut it with water first. It's also expensive, about $30 a gallon, or $10 for a can. If you want oil to melt off the engine, that stuff will do it.
dizzel
08-02-2007 08:47 PM
EverydayDiesel
19
08-02-2007 05:36 PM
djp9747
17
03-13-2005 02:47 PM
