Electrical issue (Alt & AC)
OK what would cause the alternator to stop charging and the AC compressor to stop? Nothing else stops working, the over drive stays engaged, the speedometer/odometer keeps working. I can't say about the tach as it doesn't have one.
A couple times now, they have stopped, then a few minutes later while still driving it'll start working again.
At first I was thinking crank sensor, but it seems that the OD would stop working also? So the only other thing would be the wiring harness on the passenger wheel well?
Any ideas?
Thanks, Aaron
Any ideas?
Thanks, Aaron
I really can't think of anything else that would take out the A/C and the charging system at the same time. The relays get their feed from different fusible links.
Also from searching, i'm going to check over the harness where it goes around the head a little closer.
Well I taped up my crank sensor wire, made sure the plugs into the relays were snapped in, and also made sure the plug on the fender for the A/C and alt was plugged in good. And so far it hasn't happened again, so....
My guess is the "harness" that lays on the right fender where the little alternator wires and A/C wires all connect, then the A/C wires connect again farther down; that plug is the one place that both A/C and alternator share in common.
As soon as time allows, I am completely removing the A/C wires from that whole business and routing them around it.
Other than assembly-line convenience, I can see no reasonable excuse for wiring it like it is.
midland
12-26-2012 12:38 PM
Geebeer
01-24-2008 08:01 AM
jpajax
14
11-21-2006 06:36 PM
