Electric fuel pressure gauge?
Im going to be shopping for a fuel pressure setup and noticed autometer makes a fuel pressure gauge with an electric sender. This seems like the best way to keep fuel out of the cabin space for safety. Thing is, seems like everyone here likes to use the mechanical setup...why? It looks like the setup is a little pricey, but it would be worth it to keep a pressurized fuel line out of the cab, and the simplicity of hookup...
There has been quite a few failures from one of Autometer's electric fuel pressure gauges. I'd stay away. I use Westach's 30psi electric fuel pressure gauge. From Geno's ~$70 iirc.
I saw that one and marked it did you use a snubber/ restrictor for the sending unit to help reduce the pulsations. Thanks Ed
I've been running a Westach electric gauge I got used for almost a year, and save a problem with some electrical connections in the truck, it has been just fine. I dont have a snubber for the sender, but now that you mention it, it isnt a bad idea.
Daniel
Daniel
My thoughts are to run a line of choice(-4AN) from the source of pressure to the fire wall then mount the sender at the fire wall, the adjustable snubber/restrictor can either be at the fire wall or the source of pressure. putting the snubber at he fuel pr. source gives you the opportunity to shut off the entire line if there is a problem and also lets the line to the sender help in absorbing some additional pressure spikes and vibration. That is the plan so far need to order parts. Ed
It looks like a little pipe fitting. McMaster-Carr has them, just type "snubber" in the search box on their site. You want the sintered style. Don't get the one rated for water and light oil, it will allow too much pulsing. Get the one for gases.
1st Generation Admin
I don't mean to hijack but I've just temporarily installed an ISSPRO R5604 fuel pressure gauge with a 6' AN4 stainless braided line coming off the fuel pressure regulator. As such, I'm not seeing any pulsations at the gauge.
Anybody else running the same gauge with similar results?
I'm trying to decide if I need a snubber with things as they currently are.
For my 98 24v I read am not sure where that they had some serious pulses of high pressure that are not noticeable on the gauge but can cause the gauge to malfunction and it was if I recall 98.5 and 99's. Ed
nrussell
07-23-2008 08:58 PM
streetsmoker
02-22-2006 06:47 PM
commando
10-09-2005 01:00 PM
doug
05-10-2004 10:59 AM
