Dumb turbo?
Yes, that is a common upgrade. The downpipe will need to be moved back an inch or so (the wg housing is longer than non-wg) and you will need a boost reference source for the wg to function.
Ok thanks. I had read that the exhaust needed moved, that seems easy enough. Just wasn't sure if the hot side bolted on.
What would the compresor sizes be on a H1C, WH1C, and HX35.
From Gillette Diesel's webpage (http://www.gdsdieselparts.com/new_page_2.htm), the H1C (89-91) has 50mm compressor, the WH1C (91.5-93) has a 54mm compressor, and the HX35 has a 56mm compressor.
the intake opening has a slot cut in it the full circumference of the compressor wheel about midway through its depth. it prevents compressor stall or "surge/flutter" in high fuel, low rpm, high load situations. It allows boost pressure to be *recirculated* back through the compressor in the event it doesn't have anywhere to go. The MWE slot allows this air to recirculate mid pinwheel rather than blast all the way out the front of the compressor aka surge/stall. It produces a louder turbo sound when it does this as well.
good info. does any one know the mm. of the wheel on a switzer 300 for a second gen. some call it a super b i think this is the turbo i have to put on my 93 12 valve think it will work god.
Question? I had called HTT awhile back and I was told that the 350's had a larger compressor wheel. Is there any truth to that are not. I said about getting the stage III and he told me that for the one ton I should go with the stage IV because I already had a large compressor wheel. I just was curious if there is any truth to that or not.
Ryan
Ryan
It just depends on what version. There's an array of compressor/turbine wheels. Most common I believe is the 57mm wheel. There's also 62 and 64mm etc. I think the Super B is the S200 turbine wheel (Can't remember what size it is) With the 57mm comp wheel. Someone else will chime in...
Ryan
Ryan
Ryan
Ryan
Ryan, even if it is a bigger wheel (57 is the absolute largest it could be) you still don't have MWE slots. Stage III=MWE slots and 60mm, so I don't see how you could go wrong. The stage IV is also 60mm but has a more efficient wheel design, supposedly.
IanM
07-04-2011 09:26 AM
JyRO
10-07-2007 02:19 PM
