Dually Fender Light Flicker
Muted User
FOr the past month or so I've noticed that one of my marker lights is flickering and/or won't come on at all. Last night I tinkered with it and it looks like the rubber connector that attaches to the light has a bad connection.
Is there a source for these connectors?
http://www.truck-lite.com/webapp/wcs...3153&langId=-1
Other manufacturers offer the same design.
I our area Napa stocks these lamps and socket bases.
Muted User
I've seen those as well, but the problem is the 2-hole connector is what I need. All the ones that I've seen have had one power wire to the connector with a piece of copper to go to ground when you screw the mounting bolts in. I guess I could retrofit it.
jerry007
02-18-2005 02:39 PM
