Drive line binding, killing power.
#61
Did anyone suggest taking all 4 tires off the ground (with 4 jackstands) and running the truck ? You'd be able to "feel" which sector of the truck doesn't appear to want to move or not, I would think.
#62
That's a good idea too.
I just had to do that to the rear of my truck to pinpoint a shake I was getting. Turned out being a ujoint going bad and my driveshaft looked like spaghetti wobbling all over the place.
Sent from my Galaxy SIII via tapatalk 2
#63
Great idea NJTman, and I did try that. With engine off and transfer in neutral the rear moved fine (obviously some driveline resistance). In 4H not able to manually turn wheels. Started engine and everything moves fine (2 or 4). Did notice after long, long highway blast that transfer case, driveline section near it and rear diff were very hot to the touch. Normal? (fluids all fresh and maintained regularly).
#65
That's what I meant.. up on stands and running. With a laser type thermometer you can easily tell what the temperatures are up and down the truck without touching anything. I bought my Ryobi from HD, and it works pretty good. Done this a few times, myself, and it seems to help diagnose driveline issues relatively quickly.
#66
Rear drums: 100
Reaf Diff: 107
Carrier bearing: 86
Transfer: 130
Trans pan: 140
Engine pan: 140
I guess everything is within normal range?
c2equine
12-19-2009 12:39 PM
heykw
07-18-2009 11:44 PM
wreckere022002
03-26-2006 10:34 PM
Graphite600
03-03-2005 05:24 PM
