Drag racing this weekend. improve time?
We got a 15.45 with whats done to the first truck in my sig. i was thinkin we could undo the clamp where the downpipe and the exhuast connect and wire the exhaust up so exhaust exits right out of the downpipe and avoids the stock 3 inch exhuast. you think this will help??
1st Generation Admin
If your truck has the automatic transmission fluid heat exchanger that's mounted under the turbo, pinch closed one of the two engine coolant lines that supplies the exchanger. It'll keep the fluid temps cooler, thus thicker fluid, thus a little tighter connection.
Not sure about the exhaust. I usually make sure to have all the extra crap cleaned up out of the truck, take out bed liner if equipped, tailgate, tools, tool box etc. That stuff all adds up. I try to make sure I dont have a full tank of gas as that fuel is heavy as well. How bad are you spinning? Im in the same boat as you with the open diff, it sucks!! Do you still have the stock converter?
Either leave the stock steel spare tire under the bed, if equipped, or throw one in the bed, this will help a bunch with traction. Leave your exhaust hooked up, that sounds silly.
dog rocket
10-16-2007 01:05 PM
morkable
05-14-2007 02:00 PM
