Door Locks
Old 02-27-2012, 08:17 AM
j_martin's Avatar
Originally Posted by NJTman
WD-40 needs to be used with caution
I had several homeowners who used wd on their window frames. The frames, several weeks later still had the wd on them, but also was covered with a layer of dust / dirt, because WD is sticky, and leaves a residue.
From what I've found, I would prefer using a lubricant that doesn't attract dirt.
That would be graphite. It comes in little puff tubes specifically for locks.
WD 40 will get a rusty sticky lock working. PB blaster is probably better. Follow it with non residue electrical cleaner spray, then graphite.
Old 02-27-2012, 01:17 PM
jimbo486's Avatar
I've got silicone lubricant, Kan-O-Kroil and electrical contact cleaner in aerosol cans and I also have a small puff tube of graphite. I've tried the silicone lubricant on the linkage joints in the past and it seemed to free it up a little bit.
Old 02-27-2012, 01:38 PM
7horn's Avatar
I was having all these same problems with my door locks a little over a year ago. I did the same thing that NJTman did and it would fix it for a while but the problems always returned. i finally got tired of messing with it and purchased new door latches and posts here. I had a friend who owns a body shop install and adjust them for me, havent had a problem since. New lock and stricker post shouldnt run more then $120 per side to your front door.
Old 02-27-2012, 01:52 PM
jimbo486's Avatar
Just tried spraying lubricant, contact cleaner and then a few puffs of graphite inside the lock cylinder.
My findings are, that the lock still has to pop in order for the door to be opened. If I open the door and actuate the lock with the key, it's smooth as glass. Is my issue now in the lock/latch mechanism itself?
Old 02-27-2012, 09:24 PM
Thunderhog's Avatar
These guys have new latches...
http://www.jimsautoparts.com/nos_truck_parts.htm
Old 02-28-2012, 12:04 PM
simplysmn's Avatar
Heck at that price I will sell you my used 1 for Half price
but seriously if you need 1 send me a PM
nomad65
08-20-2007 06:01 PM
Mule Skinner
07-31-2003 02:37 AM
Fillerupsonny
06-04-2003 01:51 PM
Bradtothebone
05-21-2003 10:31 PM
perk
04-15-2003 08:35 PM
Quick Reply: Door Locks
