Does Dodge still speedometer angle adapters?
Does Dodge still sell speedometer angle adapters?
Does anyone know if Dodge still sells the speedo angle drive adapter that screws onto the transfer case? What about the sensor that screws onto that, and the thing w/ the gear that goes in the T case? Thanks
The adapter that goes into the trans case has a steel drive gear. I dought if you have problems with it.
The VSS you can still get from Dodge or aftermarket.
The reducer box you can still get from Dodge also. It will be hit or miss if you get the correct one. Dodge is around $145 for it. Here is a place with them cheaper. Scroll down the page about 3/4 of the way.
http://www.transmissioncenter.net/dodge.htm
I have the same problem except the little square shaft on the gear reducer spun inside the drive gear before breaking off. Now it is rounded out and has a broke piece in it. Tried three different old truck a buddy had and the gear box on all of them was seized. Think I may just throw some jb weld in there and be done.
TJ0993
11-08-2007 10:27 AM
Superduty12v
01-10-2004 02:14 PM
