Does anyone have an upgraded converter in a plow/towing truck?
Old 04-15-2009, 08:22 PM
your not figuring in the cost of the 47rh.
you already have the 518 is the nice part. Get it rebuilt with some alto clutches/HD bands and a shift kit and buy the converter and you have something nice for the street/strip/towing.
Zach had to pay decent money for his used 47rh... and i believe if i remember correctly archer39 said he had $3000 wrapped up in the whole swap? i think
I'm not against the swap at all but its a conversion really. Its not like bolt in like your 518 is.
My theory is, do the 47rh if you stumble over it. If you buy a converter for the 518 and then you do a 47rh he'll take the goerend back and you can make up the $$$ difference between the goerend 518 TC and the 47rh TC.
Old 04-15-2009, 08:31 PM
archer39's Avatar
It was about 3 grand in the end. that was figuring in all the miscellaneous stuff like spray paint, trans fluid, cutting wheels, driveshaft lengthening, trans hoses, fittings, u-joint, and a number of other things i am sure i am forgetting.
Old 04-17-2009, 10:41 AM
RamW350 dually's Avatar
Yes, I didn't factor the cost of picking up a 47RH trans whether it be used or rebuilt (but I know it's all part of the cost in the conversion process). If you can pick up a good, used 47RH in the $400-600 range then that would be ideal as it would most likely be the cheapest price you'd see for a full-size truck diesel transmission in good working order. And we all know one can be had for a price higher then stated above. Depends on where you go to get it being a junkyard, ebay, craigslist, etc. But yea having an A518 already is nice and the fact that it's a bolt-in deal is nice.
Old 04-17-2009, 10:51 PM
The_Head's Avatar
Man o Man... I'll be upgrading everything all at once, I cant wait.
Old 04-18-2009, 07:21 AM
bradshaw106's Avatar
i always thought the "discs" was referring to the lock-up clutch.
anyhow, i installed the $550 goerend special. when i talked to him the difference between the two cheaper models was befor stall. the mid grade had an upgraded stator better for towing, where as the $550 had a machined factory stator. but once the two hit stall speed the where essentially the same performance wise.
Old 04-19-2009, 08:02 PM
I thought the $550 one had a less warranty then the $650 one, that being the only difference.
Then you could step up to the big bad $950 one.
arbor x dad
02-14-2011 01:56 PM
Dlowkes7
10-23-2010 01:54 PM
1985cucv
07-31-2009 02:33 AM
1985cucv
07-30-2009 12:32 PM
Timinva
12-14-2002 06:23 AM
Quick Reply: Does anyone have an upgraded converter in a plow/towing truck?
