Dodge dual disk trouble?????
I have had a dual disk in my truck.for some time now and I seen that the clutch fork was rubbing the clutch itself and now the fork bent and its making a horrible noise until about 2 k rpm and is there any way to fix The clutch fork from hitting the clutch????? Thanks,Dominic
Can you post some pictures? I understand it's hitting but I would like to see where. A new fork is about the only option, once it's bent I doubt you will get it back to where it's supposed to be. Quad4x4 has our forks, and 2nd gen forks. Is the pressure plate damaged? I suppose you could try to get the fork out with out pulling the transmission, but I think the bails that clip the throw out to the fork would be a PIA. Be sure to look good at the pivot ball, could be the main problem.
I'd like to see a picture too, a fork can make contact with the pressure plate but no way to contact the clutch afaik.
It left unattended You will loose the pressure plate or worst get the fork stuck on one of the feathers and make a really big mess.
cconrad331
01-27-2008 09:47 AM
DSjockey
34
07-20-2007 07:03 PM
