Dependability
Old 09-13-2008 | 04:13 PM
89f150's Avatar
Dependability
How dependable would 300hp be? And what would the best way to get it be?
Old 09-13-2008 | 05:14 PM
BC847's Avatar
1st Generation Admin
VERY dependable.
- PDR 190 injectors,
- HX35 hybrid turbocharger or similar
- 3200 IP governor spring.
- Modded fuel pin.
- BHAF
- Fix the OEM kink in the factory exhaust going over the rear axle.
- Typical IP tweaks.
- IP timing at about 1.85mm or there abouts.
- A better than stock torque converter will put more power to the ground while picking up a bit better MPG.
That should give you a solid 300.
Old 09-13-2008 | 05:21 PM
Yup, these engines do fine at 300 HP.
Old 09-13-2008 | 05:23 PM
89f150's Avatar
ok THank you guys
prlsnpsdodge
05-31-2013 11:26 PM
L-ofalab
03-18-2013 03:16 PM
BigfootTrucking
03-23-2012 07:50 AM
donhov
12-13-2005 01:48 PM
Quick Reply: Dependability
