DennyT fuel pin
DennyT fuel pin
Was doing a lot of reading about this pin, seems like a really cost effective performance buy. My '93 is very stock, doesn't smoke, 156000 miles. Do these pins create a lot of smoke? Any info would be great,
Thanks
Thanks
i have a Denny T pin and with my turned up pump it's a MONSTER! smokes more too till the hx35 spools up then it just hazes. But with a stock pump im not sure what the outcome would be. i love my denny t pin tho
I have a performance fuel pin installed on my stock pump.........it only smokes on hard exceleration. Most of the time is burns clean/clear. If you want black smoke.........turning up the fuel settings will get you there.
If I recall correctly, it wasn't a groove, just a little wear mark where the actual fuel pin was traveling on the cone. Nothing to worry about.
On my bone stock auto, after I installed the DennyT cone, it puts out a nice little puff when I floor it when the turbo isn't spooled, other than that, it's a haze after the turbo spools. I don't hot rod by any means, but I highly recommend one. It made my truck much more enjoyable to drive, and it seems like my fuel mileage may have actually increased some (after the initial "break in" period... ) which I think is due to not taking as much fuel or time to get to speed from a stop.
As I said before, I highly recommend one, and Dennis is a pleasure to deal with. Very fast shipping, and very reasonable price.
Mine grooved pretty bad and was causing the little pin inside the pump to catch on it. I just took a dremel to it and fixed it up and it's been alright since. Either way, it's worth the money.
