Are DDP4's going to be enough or should I order some larger???
The Scheid VE Pump, Aurora 4000, HG, and head studs are all ordered and on the way. In my search for the first 12 second 5 speed first gen, will the DDP4 injectors be large enough or should I go ahead and get a different set? They have made some good power with a junk VE and should do even better with the built one. I think anyway.
Any of the pro's know if this will be enough, or will I need larger ones? I dont want the monster 6x16's that are popular. They just seem way to overfueled.
Need to get the fuel to and from the 14mm as efficiently and quickly as possible. Never heard of a 14mm VE that didn't have at least 6x16's. 6x16's are gonna run cleaner than 5x18 lol. The stock I/C piston was designed for a 6 hole Injector
I've looked at the LBPD injectors and they look nice. The DDP4 are just 4 hole injectors. I could just order some new 6x16 tips to put on these injectors right? They only have about a thousand miles or so on them. And I sold the stock ones already.
Just for comparison
My honed 370's are 5X13 (70-lmp) Made 600+hp
My DDP 4's are 5X14 (72-lpm) Made 600+hp Sent them back to DDP and had them honed out to 5X16 (76-lpm) Made 600+hp.
I also have a set of 5X28 (100-lpm) that have made over 600+hp.
My last set of injectors that I have is honed 185's that measure out to 5x10. I haven’t done any testing with them to see what they are capable of doing. When I put my 12mm pump back on I might throw them in there to see what kind of power they might make.
Stomp
Are you sure the DDP’s you have only have 4 holes? I think most of the DDP injectors are 5 holes. DDP can make whatever size you want. You can also send you’re injectors in and have them honed out some more. It would probably be cheaper than buying another set.
Just for comparison
Stomp
Just for comparison
Stomp
Thanks for all the great info!!!
my ddp4 injectors are 4 hole as well. I was told DDP did have some 4 hole ddp4 injectors, but that most were 5 hole.
Just for comparison
Stomp
Just for comparison
Stomp
Out with the old and in with the new....
Both DDP's the one on the bottom is a DDP4 my old injector and the one on the top is my new set 70+LPM DDP's
