dash board
Old 02-09-2012, 07:55 PM
19mike92's Avatar
dash board
I know its been asked before, but does anyone make an aftermarket dash peice for these trucks? i asked my dealer and they told me they have been discontinued but they used to cost $614.
Old 02-09-2012, 09:04 PM
simplysmn's Avatar
Find 1 from a gas truck and just swap your vin plate over
Old 02-09-2012, 09:28 PM
93flatbed's Avatar
What piece? The whole carrier? I have not been able to find the whole thing. I do remember finding some sort of a "cap" for the top of the dash. But seemed a little hookie for me. Of course a nice dash mat will cover good enough.
Old 02-10-2012, 12:52 AM
simplysmn's Avatar
Yes you can unbolt the whole dash it has a row of screw's under the rubber windshield lip and then there are 2 1/2 in bolt's 1 on each side of dash and a few ground wires to pull if your's is cracked or beat up I would just find a good 1 from another truck and swap out the vin plate easy to do shouldn't take but a couple hour's to handle the only tricky part is the row of screw's at the top under the rubber you either have to cut around each screw or take a slice out of the rubber big enough to get them out .
Old 02-10-2012, 09:45 AM
gyman98's Avatar
I made a piece from a extra ballister from my deck. Its a 5/8 alumnium rod, cut on a angle and then sharpened. After you find the screw you just hammer the rod on the rubber over the screw and it cuts a neat plug right out then you can just glue it back into place when you are done
Old 02-10-2012, 03:34 PM
19mike92's Avatar
im trying to find the entire dash peice. and so far, every scrapyard around here has turned up nothing descent.
Old 02-10-2012, 03:50 PM
simplysmn's Avatar
what color are you looking for ?
Old 02-10-2012, 06:37 PM
Buddy Stewert's Avatar
I got one Gray
Old 02-11-2012, 10:49 AM
cougar's Avatar
Be very careful about transferring VIN plates. You can be accused of auto theft.
Old 02-11-2012, 10:53 AM
simplysmn's Avatar
Not if you are just changing out the dash and you can show paper work from someone you bought the dash from Besides is there really a number on theses frames I took apart 4 81-93 dodge truck's and Never found a vin on any of the frames
Old 02-11-2012, 12:00 PM
Vin # Is on the fire wall om my 93
Old 02-11-2012, 01:15 PM
CarlJensen's Avatar
Dash caps. If you have enough left to glue it onto.
http://www.dashcoversplus.com/site/1427228/page/864510
another:
http://www.coverlaymfg.com/
Old 02-11-2012, 02:56 PM
simplysmn's Avatar
Hey Buddy it should also be on the dash
Old 02-11-2012, 03:30 PM
19mike92's Avatar
mines not cracked where everyone could see it, just wherever something gets screwed onto it or where it screws to the cab is broken
Old 02-12-2012, 11:37 AM
cougar's Avatar
Alaska State Trooper, AK DMV, and AK DOT will tell you different. Fortunately for me I hadn't changed it yet.
Quick Reply: dash board
