Dana 70......Posi or Detroit Locker ????
Hey guy's, I have now ordered enough stuff to start making a little more power, since this is going to be my daily driver untill I can find a "MINT" Dually, I would like to put a POSI unit in it or maybe a locker......This truck was ordered with NOTHING except A/C and an Auto O/D....not even a posi unit.......anyway what do you think would be better for all year service ???? Keep in mind it is about HALF the cost to put a locker in.......Canucktrucks
Personally, I'd go with a limited slip. A Detroit can be downright scary on icy roads.
I have Detroits in both ends of my Jeep, and I'd never use them for a daily driver where there was a lot of snow and ice. The Detroit also has some "quirks," but with the longer wheelbase and automatic they would be much less noticable in the truck than my Jeep.
Re: Dana 70......Posi or Detroit Locker ????
Originally posted by canucktrucks
Keep in mind it is about HALF the cost to put a locker in.......Canucktrucks [/B]
I would vote for the powr-lok. By far the strongest limited slip "pozi" for a dana.
"Powr-Lok (P/L)
This clutch type limited slip is the strongest and most aggressive limited slip differential available from Dana Spicer. It is a clutch type unit using floating cross shafts that ride up on ramps in the case. When power is applied, the shafts ride up the ramps and load the clutches for a positive engagement. A Power-Lok will not lock up 100%, but it is a very durable unit that will hold up fairly well with tall tires. It can be rebuilt, and can be set up smooth or aggressive by changing the clutch design or stacking configuration. Powr-Loks are easily identified by their 2-piece case. They are a very strong unit due to the 4 spider gear design that provides twice as many teeth to carry the load as a 2 spider gear unit does. However, the case bolts can stretch or loosen after severe use over time."
"Powr-Lok (P/L)
In all honesty, unless you get heavy on the coal, it's controllable. But other than a daily driver what do you plan to do with the truck? If it's just going to see street duty/towing, I'd stick with a limited slip, but if you're going to pull sleds or get into the muck, then I'd say locker. It's manners are,,,it's manners, but they're livable, and after awhile you don't notice it anymore, just gotta be careful when it's slick out to keep your foot from getting buried. It'll let you know real quick when you're pushing too hard
One advantage... In 4wd low on dirt I can hold it to the floor and it takes off like I was launching on the street
The ARB has no limited slip feature - it is an open carrier or spooled when locked. The E-locker does offer a limited slip when unlocked and so does the eletrac from Detroit but these units are far from "tried and true". I can't really comment on the real world durability of either of those two lockers.
Unless you're stuck, an open diff is the best thing on slippery roads. My '85 D250 with skinny little tires and 500 pounds of cement blocks over the axles got me through deep snow (passed school busses stuck on hills) without fail. Open diffs are very forgiving of stupid driving. I've driven both lockers and limited slips on slippery surfaces. You do have to be a little more careful with the locker than with the LS, but it's not much of a difference. They'll both bite you in the butt if you get stupid with the skinny pedal, but that's the nature of the beast. If you loop the truck with a locker, it would've looped with an LS, too. You can't blame the diff for a heavy foot. If you don't mind the bang when the thing unlocks when you go around corners, get a locker. If it stops banging, look for a broken axle. I drove a bus around for a couple of weeks before the other axle broke. I thought it got kinda quiet back there.
Location: Smith Valley, NV (sometimes Redwood City, CA)
The Dodge LS is a very good unit. Even if one wheel is off the ground you can feather the brake and get it to lock and put some serious power to the traction tire. Around town you may never know it's there except for a chirp sometimes on right hand corners. In sand it just works and I was surprised where I could go. No drama, just excellent traction.
Wetspirit
Wetspirit
Patron Saint of 1st gens
I'd cast my vote for the LS as well.... in fact I have one that needs to be incorporated into MY open diff too. Dumb bunnies that chose the "open" ....some people.
pastor bob...
pastor bob...
nate_88
07-19-2009 06:20 PM
jmccart
07-10-2007 11:46 AM
jmccart
07-07-2007 12:46 PM
Extreme Diesel
12-02-2002 11:20 AM
