Dana 60 front studs or cab I use bolts
So I am replacing the u bolts on the front axle because the driver side is coming loose and I want to replace them all and the studs are actually starting to look really bad and are thin we’re the plate sits like it has been rubbing can I replace them with grade 8 bolts or do they have to be studs
thanks guys
thanks guys
You got all your other parts on-line, you can do the same for the studs. Only kicker is you may have to get a box or bag instead of just the couple you need. That's how I ended up with all these extra manifold studs...
I was able to find a spring shop up near jennerstown which is about 40 min from me and I will actually be out that way getting some roofing panels for a job I have coming up he just wants 38.00 bucks for both studs when a grade at is like 8 bucks for both lol but I figured it came that way so that’s the way it should go back together
I agree I have tried to upgrade and improve as much as I can have been debating on buying jungles cross over frame boxing kit since I’m going to be pulling the motor in a week to send it out for a refresh after working the truck super hard on this last job I did
I don’t really have larger ties or anything like that it’s just with the plow hanging off the front and all the driving I do with it in the winter I just want it to drive as well as it can, my only thing is o don’t know of the crossover will work with the plow brackets in the front
nonrev (07-10-2021)
Hmm really I figured it would be an upgrade for the truck I see on far from stock they have the push pull arm that is adjustable would that be any kind of up for the truck,
