Dana 60 & Dana 70 Problems
Well it seems the more i fix in this truck the more things that are bad pop up. I figure eventually i will get it all but right now it is very frustrating. I bought new seals for everything from the front to the back of the truck. I went to replace the front Pinion Seal and when i grabbed the front drive shaft i noticed that the coupler that goes into the transfer case has a huge amount of play when i turn it left to right "Is this just the U joint i have to replace?". I then went to take the u joint off the front differential and the side caps just fell out in my hand "so now i need new u joints" Anyway i continued on to replace the pinion seal and when i grabbed the output of the pinion it also has huge movement in all directions. What does this mean and what do i have to get to fix this?
On a side note i dont know if it is related but yesterday i came to a stop at a stoplight and when i went to go again the truck felt like it has the parking brake on "or something was holding me back" I stepped on the gas and it broke free and seemed okay. Then about 30 minutes later once again i come to a stop and when i go again same thing happens. Any idea what this could be?
Thanks for the help
Chris
Thanks for the help
Chris
Does anybody have a rebuild sheet for the Dana 60 and Dana 70? Since there is not a sticky here on how to rebuild them i figured i would give it a shot. But im going to need the specs.
Thanks
Chris
Thanks
Chris
As for the rest well, when stuff wears out you just gotta replace/rebuild it. How many miles on that rig, anyway?
The output shaft on the transfer case also has even more play left to right. Really scary i could only imagine what is happening at high rpms. Weird thing though is there is no noise or shaking so to speak. Well maybe there is and i just think that is normal..haha..
Chris
