D70 axle spindle threads boogered up
One of the axle spindles threads is all messed up from a previous owner. I had to laugh at a previous post in a thread where the owner said he found a nail being used to hold the nylock nut in place. I had something similiar, a screw was used. Had to back it out. The original nut is all boogered up too. I went and bought a new one at NAPA, and it wouldn't even go on without loosing all of it's threads. There went $16. I tried a thread file and some regular files to clean the threads up but that didn't help. Long story short, ended up placing two lock washers (old style) behind the original boogered up nylock nut. This sorta spaced it out further to where it had 'good' threads and would hold tight. Without the two washers the nut would get loose before the hub unit would get tight.
Well now I have a oil seal leak from that side. Should've put a new seal in when I did the brake job a few weeks ago[rolleyes]. Since I'm going to pull the two wheels, axle shaft and hub again to replace the seal, figured I'd try to fix these threads up/do it right etc.
My question or point of this thread is, is there a die this big to cut new threads or clean these boogered threads up? I imagine it would be high dollar, if one exists I wonder if a drivetrain shop would loan it out, for a fee of course...?
Bill, try a truck shop. Medium to heavy truck work. We have one here that does alot of Dana/Spicer work on axles of all sizes, they actually beat just about any pricing I found online for a D70 rebuild kit. It would have been about the same with shipping. I think that would be your best bet for something like a tap for the axle.
Are you sure the spindle isn't "egg-shaped" a bit from whatever buggared the threads ??
Go to the junk-yard and find some of the MUCH HARDER old-style nuts, just like the ones in the top picture here :
http://quad4x4.com/Dodge%20Rear%20Axle.htm
Take a SHARP square file and cut three equally spaced notches on the inside of one of these nuts, thereby creating a thread-chasing die of sorts.
To clean up and sharpen the threads on this home-made die, run it on and off a good spindle several times.
A lot of tedious filing and time, but this trick may save a lot of dollars otherwise.
Bobcat698
15
05-19-2010 05:50 PM
