Cycling AC switch
Cycling AC switch
I've taken the advise of the great board here to get my air conditioning blowing colder now that summers coming.
I pulled the copper temp sensor most of the way out of the AC tube near the fire wall and it's blowing colder now. The issue is, is that sometimes its so cold you could get a headache and other times it's just so-so. The so-so times when I shut off the AC switch on the dash I cannot hear the rpm or the sound change so I'm assuming it still acts up and the compressor is not on.
Other times when it's blowing freezing cold I can hear the difference when I turn off the ac on the dash. Something is amiss still causing the compressor not to cycle sometimes.
Any suggestions? and if so what would be the fix procedure? What needs to be replaced/looked at?
thanks,
thanks,
kawi600
06-04-2006 03:13 PM
