"Custom Duals" almost done!! Pics
Old 12-13-2008 | 05:06 PM
DNRCustoms's Avatar
Well, All I need is two more 45 degree bends and I'll have it finished.. Tell me what you think so far..
It is pretty cool, because it is symetric at the splitter, I have it dead in the center, so it was pretty easy to do.. I was able to use all 45 degree bends, just had to cut to size and twist.. If I know it would have been so easy, I would've done 5"...
Old 12-13-2008 | 05:20 PM
weymo64's Avatar
Very nice. Keep up the good work... cant wait to see it all done.
Old 12-13-2008 | 05:48 PM
NO_SPRK's Avatar
looks great!
Old 12-13-2008 | 06:10 PM
archer39's Avatar
very nice work. But personally don't like duel exhaust (excluding stacks) on diesels.
Old 12-13-2008 | 06:12 PM
NO_SPRK's Avatar
im also not into duals as much but i'd love smoking people out on both ends!!
no matter what you've done a good job. is it 4inch the whole way?
oh and did you do a shackle flip in the rear? what are those leaf springs off of?
Old 12-13-2008 | 06:39 PM
DNRCustoms's Avatar
Well the reason I did duals, is because I can smoke out both sides of the road..lol And everybody has stacks on the first gens... I like to be different, plus I didn't want all the soot all over my nice new paint job... It is 4" from the turbo with a 2nd gen dp... It is necked down just a little at the flange, but I think they all are like that until you do a different turbo..
Ya, I made my own shackles, They give 8" of lift over the stock setup, so I removed the factory blocks and I am plus 2 in the rear over stock.. Then I made my own top plates and new shock mounts.. They are still stock springs..for now!! I will be busting them apart and trying the spring tip poly puck insert deal that Jim Lane did..
Old 12-13-2008 | 07:19 PM
STACKED's Avatar
i like it. keep it commin
Old 12-13-2008 | 07:41 PM
SmokemS's Avatar
thats sweet
Old 12-13-2008 | 07:54 PM
COUNTRYBOY's Avatar
I'm running the same muffler, you'll love the sound! Great job, wished I had duals....
Old 12-13-2008 | 08:02 PM
jogl's Avatar
What does that aero turbine sound like?
JP.
Old 12-13-2008 | 08:03 PM
u.s mma's Avatar
DNR, where did you order your 4" parts? I just got a 4" 2nd gen downpipe, but am lacking the rest. When you get the chance you should get some audio of how she sounds and post it up.
Old 12-13-2008 | 08:04 PM
Ace's Avatar
Ace
I'll bet that's same muff Tanklage was talking about over on 1st Gen.
Old 12-13-2008 | 08:11 PM
COUNTRYBOY's Avatar
JP.
Has lots of turbo whine/whistle at idle and a nice deep tone. Not loud IMO, it was stright piped when I bought it and went with Pinnicle's exhaust kit, but let them keep the muffler because I had already had the AERO turbine waiting.
Old 12-13-2008 | 08:21 PM
DNRCustoms's Avatar
I got all my parts from this place.. http://www.expanditperformance.com/
they had awesome prices.. They sell the 4" piping to go around our t-case... I ordered the 2nd gen dp from them, and the two pieces to get around the t-case, But I ended up only using one of them and putting like a 10" straight piece inbetween the dp and the pipe I got from them and it worked perfectly.. Then I cut it right at the back of the t-case and twisted it a liitle to make the angle better, It was ok... But I wanted it perfect..lol Then I orderd 4 45 bends from them, prices were real cheap, like 13-14 bucks each... And the rest is history.. If you want, I can look at the part# on the pipe I didn't use so you don't order that one.. Let me know if you need any help, it is all fresh in my mind...
When I get it all hooked up, I will get a little vid of how it sounds... I am curious, I have the 5" version on my 06... But I think it will sound even cooler on the first gen... I want to start it so bad, but I really want to wait untill it is all done!!
Old 12-13-2008 | 08:31 PM
Looks great!
